Bimmerfest - BMW Forums - View Single Post - E39 540i low compression
Old 02-11-2011, 10:48 PM
Flug540's Avatar
Flug540 Flug540 is offline
Mein Auto: 1998 BMW 540i 6-spd
Originally Posted by Mercutio2511 View Post
what process are u using to check the compression ratio of ur engine?
Umm OP i always open the throttle all the way when im checking for compression ratio..and the engine temperature is a factor...and the oil...and i always disable the fuel injection system too..
That's what I do too:
- Let the engine run until the operating temperature is reached;
- Remove DME relay;
- Remove all ignition coils/spark plugs;
- Attach the gauge;
- Crank the engine 6 times with the throttle open all the way;
Wet test is done the same way except a teaspoon of oil is added to the cylinder before the gauge is screwed in.
