Bimmerfest - BMW Forums - View Single Post - What's with the E60 Rear Turn Signals?
Old 02-21-2011, 11:21 PM
Nube1kenobi's Avatar
Nube1kenobi Nube1kenobi is offline
U of Dawgs
Mein Auto: 08 535iA Spt/11 X5 35i
Originally Posted by bimmerstien View Post
Is there a lamp socket or wiring harness problem these cars are known to have?
I had the same issue before except on the opposite side. All the bulbs were good but the connector shell was burnt due to sparking and arcing on the brown and white wire terminal - very high resistance, possibly just barely making contact. The dealer replaced both the male and female connector shell and all is well again. Keep an eye on your issue. Mine started with the turn signal failure, then brake, then reverse light... they kept cycling all over. When I looked, the connector was toast and that brown/white terminal was loose (possibly bad insertion) and burnt. You would think that somethng like that would pop a fuse but never did... and all the bulbs were good.
Nube1Kenobi
2011 X5 35i Sport Activity|Plat Gray/Beige/Dk Poplar|Conv Pkg|Cold WX Pkg|Tech Pkg|Prem Sound|Comfort Seats|Hitch|
2008 535i Mon Blue/Dakota Blk/Dk Poplar|Sports Pkg|Prem Pkg|Cold WX Pkg|Nav|RTTI|PDC|L7|HD|I-Pod/USB|PWR Rr shade|Sports Auto - paddles|Active Stg|Comfort Access|F/D R/seats|Rr DMS Airbags|Adaptive Xenons
Do not argue with an idiot else he lowers you to his level and beat you down with experience..
