Bimmerfest - BMW Forums - View Single Post - What's with the E60 Rear Turn Signals?
Old 02-22-2011, 10:42 AM
ArtchredTTU ArtchredTTU is offline
Mein Auto: 550i
Originally Posted by bimmerstien View Post
Had the CPO two weeks and the left turn signal clicks triple-time. I get a bulb symbol on the I-Drive that says left rear turn signal malfunction and sometime I get a break light malfunction.
I pulled the felt liner out and removed the bulb cluster but couldn't figure out how to get to the turn signal section I saw three torx screws and figured they probably had to be removed. I put the bulb cluster back in and the problem went away.
Is there a lamp socket or wiring harness problem these cars are known to have? Everything looked clean to me; no corrosion.
BTW, how do you get to the rear signal light section where the LED's are?
Wait i have a question???!!!!! When you press gently on the turn signal, is it suppose to click 3 times?? Like when your changing lanes?? I have to hold mine down or else it clicks once.. If that isn't ok I will take it to the dealer asap!
