Bimmerfest - BMW Forums - View Single Post - 88 735i turns over won't start
Old 02-23-2011, 06:41 AM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Leaf Tekna
Sounds like too much fuel or not enough air.
Do you have a way to check for fault codes?
Doubt its the injectors -- they wouldn't all go at the same time. But maybe they open too long.
Fuel pressure regulator.
Idle control valve.
Position Sensors?
Coolant temp sensor (less likely)
