Old 02-27-2011, 07:18 PM
AzNMpower32's Avatar
Tar Heel Faithful
The headlight washer sprays the first time the windshield is washed when the headlamps are on, and every 5th time after that.
If you are hearing the pump activate but nothing is spraying, check the hose connection next to the washer fluid tank for any clogs or leaks. If all is okay, likely your pump has gone bad and needs to be replaced (this was my case last year). The part is around $60-70 and easy to do yourself.
