Bimmerfest - BMW Forums - View Single Post - 88 735i turns over won't start
Old 03-01-2011, 02:16 PM
Jrvna Jrvna is offline
Mein Auto: 1984 633csi
Hey, I have a 633csi. It did the same thing, Mine had a relay problem. Next to the fuse box under the hood, there are 2 relays. The one closer to the fire wall was bad. we replaced it, with a bosh. because the car was old NAPA auto parts matched it to a newer relay and that fixed the problem. Also under the starter there is a sensor that also went bad, and the symptoms of that were very similar, to what you are describing. Hope it helps!!
