Old 03-02-2011, 07:48 PM
franka franka is offline
Mein Auto: E39 540i Sport
540alex,
An engine with enough miles to have low compression could also have less than specified closed and/or open spring loads on one or more valve springs. Please don't misread this. I'm not saying weak springs are the case of your low compression. I am saying that the miles that would cause your worn seats would probably cause some springs to be below spec loads. With your meticulous cleaning it would be a shame to reinstall even one weak spring. Even worse to not check them at all
I realize its easy to sit here and suggest things for you to do but I would be remiss to know this and not mention it.
Frank
540/6
Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
