My SRS light is on by following pattern:
- turn key to 2: light is on, then in 2-3 sec off for few sec and then back on
after that stays on.
I checked AIRBAG unit with carsoft 6.5 and it says OK without any codes. I did reset it just in case. Also I've noticed that I have errors in Instrumental Clusters module but didn't see codes yet (just was able to set up carsoft finally).
Why it's on then if no codes? Can it be some electrical problem (fuse, connector etc). BTW I check passenger seat mat - all connections are fine there....
That's funny I've used carsoft 6.5 to read and clear codes from my SRS. Are you connecting to the plug in the engine compartment or under the drivers dash?
I didn't realize Carsoft 6.5 could reset the airbag light.
We should add that to one of these threads, for reference purposes, so that all knowledge is in the canonical threads for ease of location.
- Description of Carsoft, GT1, INPA, DIS, EDIABAS, & Peake (1) & which can modify the auto-lock car door feature (1) & what does Carsoft do anyway (1) (2) (3) (4)
two ways to reset the light, one make sure all the sensors are working properly, two use the proper tool to reset it. plus, it has also been noted that if you have worked on the doors, and unpluged the airbag and didn't dissconect the batt. first it will set off the light, and needs a reset tool.
NOTE-----PLEASE BE VERY CAREFULL USEING CARSOFT SOFTWARE, IF YOU DON'T HAVE COMPLETE KNOWLEDGE ON HOW TO USE THE PROGRAM YOU CAN RENDER YOUR CAR UNDRIVEABLE.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
