04-01-2011, 07:42 PM
My Reality Check bounced
Mein Auto: 09 328i 6MT Cabrio
Originally Posted by pointandgo
I think there's another question, Kat. Since your light reflector(s) are now perfectly matched to your OE bulb for an ideal beam pattern, will any replacement bulb be of the same size/dimensions, and not adversely affect your beam pattern.
I'm not sure I understand your question.
When you say reflectors, I am presuming you mean the corona rings (to use the proper BMW terminology). From what I understand in my reading, that is where many aftermarket solutions fall short.
There is one bulb that illuminated the inner ring and the outer ring is lit purely by reflection off the inner ring. If I correctly understand what I've read, aligning the bulb in the socket is critical to getting the rings to illuminate, let alone illuminate properly.
Apparently, the aftermarket bulbs are the correct dimensions, but we all know that just because its the right size doesn't mean it necessarily does the job properly.
