04-12-2011, 01:33 PM
Originally Posted by bobdmac
Have you tried this one?
I have. With mixed results.
BTW, today a 'propane' way to test for vacuum leaks was proposed:
- E39 (1997 - 2003) > 2003 525IT-Smog Failed
Originally Posted by Jimmys 530i
Check for vacuum leaks. Buy a small propane tank, and run a long hose off the end; open the valve just slightly, and hold the hose over vacuum components one at a time. If your idle changes, you have found your leak.
