Old 04-13-2011, 06:19 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Originally Posted by Soshrillitsill View Post
Does anyone know if you can lift an X3? I'm trying to get some bigger tires to make it look better and do better when camping off road. I was thinking that just getting a little bit bigger shocks it could lift it by just a few inches. Has anyone done something like this? If so what did you do and how larg of tires can an X3 fit? I saw that there was a hunter conversion that did this but I can't find what they used to do it. Below is the link.
One of the things I'd be worried about is the angle of the driveshaft if you lift it. You'd probably have to lower the transfer case somehow to avoid putting a ton of stress and premature wear on your gears in the rear diff bc the angle of the drive shaft would increase.
