04-22-2011, 12:25 PM
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Hi Willis
A functioning OEM amp is required for this harness to work.
The issue with the Logic7/Premium OEM amp is that it is a digital-proprietary (MOST) inputs amp so a proprietary device is required to handle those inputs. There is no aftermarket amp that can be used to directly replace your OEM amp.
There is a MOST preamp device available for certain BMW but it is not available for the 7-Series in particular: http://www.mobridge.us/sites/default..._Manual_V3.pdf
Originally Posted by drez14
Hello,
I think i might need some clarification on how this works. I have a E66 with an L7 amp that is broken (wont drive the subs) Will this device help me go around my broken amp, or do i need a properly functioning amp for this to work. At first i thought that this will bypass the amp, but im beginning to get the feeling (from reading other posts about L7), that this will only convert the high output signals from a working amp to low output signals to be routed to an aftermarket amp.thanks
Willis
