04-23-2011, 05:25 AM
Mein Auto: 2007 BMW X5 4.8i
Amplifier harness for E70 X5 with Hifi stereo
Originally Posted by Technic
Improved harness is now available:
- add a trunk sub and/or power the underseat woofers with a separate amp, no need to cut OEM wires or harness itself
- quick underseat woofers connectors with 12AWG wires labeled for easy connection to your aftermarket amp outputs
Price the same, $85 shipped... :thumbsup:
I am designing an audio system for my 2007 E70 X5 and I would like to use one of your wiring harnesses, they look great and I would prefer to not have to splice into the factory wiring harness if possible.
I am planning on using the JBL MS-8 connected to a JL Audio HD900/5 amplifier.
The MS-8 requires either a full range low level input or several speaker level inputs that can be summed to provide the full range signal. I would prefer the speaker level input, to remove the LOC from the picture and reduce the possibility of noise in the system.
Can you provide a harness that would have the speaker outputs clearly indicated that can just be plugged directly into the amplifier? If so, I would like to order one.
Thanks in advance
Chris
Newfoundland, Canada
