04-23-2011, 02:17 PM
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Hi Chris
I can create a MS-8 to OEM harness (no LOC) for full integration depending of the X5 OEM system. I have no Top HiFi harnesses available for the next 3-4 weeks, though.
Originally Posted by gadg8man
I am designing an audio system for my 2007 E70 X5 and I would like to use one of your wiring harnesses, they look great and I would prefer to not have to splice into the factory wiring harness if possible.
I am planning on using the JBL MS-8 connected to a JL Audio HD900/5 amplifier.
The MS-8 requires either a full range low level input or several speaker level inputs that can be summed to provide the full range signal. I would prefer the speaker level input, to remove the LOC from the picture and reduce the possibility of noise in the system.
Can you provide a harness that would have the speaker outputs clearly indicated that can just be plugged directly into the amplifier? If so, I would like to order one.
Thanks in advance
Chris
Newfoundland, Canada
