Bimmerfest - BMW Forums - View Single Post - eas | VF420 Supercharger Installation - 2004 BMW e46 M3
Old 05-09-2011, 10:04 AM
tom @ eas's Avatar
tom @ eas tom @ eas is offline
european auto source
Mein Auto: BMW
As many of you know, david @ eas suffered from a failed rod bearing in his 2004 BMW M3. Upon further inspection, we noticed the exhaust cam bolts were also backing out - as a few reports from others have confirmed as well. Thus, a donor S54 was sourced with about 70K on the clock and quickly torn down. A fresh set of VAC's Coated Rod Bearings were installed along with new bolts on the cam gears to prevent any future issues.
Preventative maintenance is a must - normally aspirated or otherwise. After installation, a compression/leakdown test was performed and the engine given a clean bill of health, and David was back on the road. After the 1200mi break-in for the rod bearings, this M3 was able to pull a very respectable 277whp on the dyno - indicating a strong baseline for a stock engine.
VF420 Supercharger
We are firm believers in the parts we sell, and run many of them on our own BMWs. At the time with MFest V just around the corner, we decided that it would be great to install a VF420 Supercharger system and some Cool Carbon pads and hit the track.
Here is a completed shot of the install, showing the the new Vortech Compressor - which feature the Black Ceramic coating for an aggressive appearance the hood is popped open. Supercharger mounting bracket is also hard anodized for durability as well as a stealth appearance.
Some quick pics of David's M3 on LVMS @ MFest V:
Respectable numbers can be made with VF's entry level kit, and with a relatively small investment, any e46 M3 can achieve similar numbers for great fun both on and off the track.
Feel free to contact us if you should have any questions!
