Bimmerfest - BMW Forums - View Single Post - Mechanical things you need to know about your E34 - UPDATED 3/22/11
Old 05-17-2011, 03:50 PM
beatbrains beatbrains is offline
Mein Auto: 97' 3128i & 94' 540i
okay thank you. I will repost. I found a mechanic in the area who works on BMWs. Hopefully he can help. The other mechanic checked mostly all those things. He said that the crank sensor was bad and replaced that. also replaced the fuel pump relay. he mentioned something about spark & injector pulse not being present...and my cooling temp sensor actually checked out. I think he is suggesting i do a electrical overhaul
