Just did the front moldings/covers (did it dry no soap ) easy as pie just use a shop vac and mineral spirits to clean channel and line up new molding ,I started at top rt corner and then went down side then other side just use the heel of your hand and the top pops right in ! NOW I need to know for SURE if the rear works the same way? ( without removing glass ) problem is I got a small leak in rear window BUT my sunroof broke ,mechanism, so the sunroof is not closing tightly ? so is the leak the sunroof or the rear glass???????
2000 528i sport package
