Bimmerfest - BMW Forums - View Single Post - Technic PnP :: Logic7/HK (677) PnP Trunk Sub Harness
Old 05-26-2011, 09:26 PM
g9buf g9buf is offline
Mein Auto: E60 M5
Originally Posted by Technic View Post
As a quick and efficient solution for those that would like to either add a trunk sub or replace the OEM woofers with SWS-8 (or doing both), this is a custom made, plug 'n play complete harness with a built in, 150W max Navone LOC -custom made for this particular application- with remote turn on signal output right at the harness itself -no need to run a remote wire from the cabin.
This harness connects between the OEM amp and the OEM audio connector using OEM connectors, wires are properly soldered and labeled so no OEM wires need to be cut, spliced or tapped cut. Just plug it and add the amp. Navone LOC takes care of the Logic7 high power woofer outputs, so interface with any aftermarket amp is guaranteed.
Quantities are very limited as this is just a test of the potential market of a harness like this. It can be also used in 1-, 3-Series and X5/X6 Individual Audio/Premium systems.
Price: $75 thru PayPal shipped in the USA, 1 year warranty in case of defects or malfunctions. Warranty void if harness is modified in any way.
hello mate im in the uk i want 1 of these looms for my e60 m5 with logic 7 could you send one over for me ?? thanks dude
