Bimmerfest - BMW Forums - View Single Post - DISA 0 Ring
Thread: DISA 0 Ring
Old 05-30-2011, 11:39 PM
spamboxer spamboxer is offline
Mein Auto: 01' 530i
silicone
Originally Posted by champaign777 View Post
i really don't care 7$ or 12$
yap, red one from ebay is the way to go , match perfect
silicon is a big NO NO, you don't want to see this staff in your cylinders, don't you ?
do you know material from which your replacement O-RING is made?
and whats wrong with silicone? how should it get into cylinders?
Silicone is acceptable for temperature applications between -65 degrees F (-54 degrees C) to 450 degrees F (232 degrees C). It has good resistance to ozone, weather, detergent, salt water, engine and transmission oil, non-petroleum brake fluid, hydraulic fluids that resist fire, vegetable and animal oils, and high molecular weight chlorinated aromatic hydrocarbons.
Silicone is vulnerable to mechanical wear and tear, water and steam over 250 degrees F (121 degrees C), aromatic hydrocarbons (benzene), chlorinated hydrocarbons (trichloroethylene), acids and bases, and hydrocarbon fuels.
