Thread: DISA 0 Ring
Old 05-31-2011, 06:38 AM
poolman poolman is online now
Mein Auto: 525i station wagon
Vacuum from the engine would pull the silicone into the cylinders. Now if your smart and use sensor safe silicone there wouldn't be any problem. The only problem with small bits of silicone getting into the cylinders would be that once burned the stuff would contaminate your 02 sensors. The stuff is so sofet that there wouldn't a problem to the combustion chamber, unless your pour huge amounts in. For the amount thats going to be used to seal off the DISA valve, only small and I mean very small particles would be pulled into the engine. I don't see where this would cause any problems what so ever.
