Bimmerfest - BMW Forums - View Single Post - 1999 BMW 528i E39 Radiator hoses
Old 06-08-2011, 11:03 PM
In the bestlinks, there are the following related hints posted after thinking about the hose-removal problem for a while:
- How not to remove the large radiator hose connector spring clips (1)
In addition, the team came up with the following hints that the OP will do well to read and learn from:
- How not to remove the nipple from the E39 radiator (broken radiator nipple)
- How not to put your E39 fan clutch back on (crooked fan clutch nut)
- How not to bleed your E39 cooling system (1) (broken bleeder screw)
- How not to replace your E39 thermostat (thermostat loom misplaced)
- How not to remove your E39 expansion tank (broken expansion tank nipple & cn90 repair)
(Note: I do realize I ended that "team" sentence with a preposition; I never did understand that grammatical rule.)
