Old 06-18-2011, 01:26 PM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Originally Posted by Boostednut View Post
I need one of these I have a 2002 745Li I will check to see if I have the logic 7 my goal is to run aftermarket subs/amp and run a separate amp on the front and rear high/mid speakers..is this possible?
This Logic7 harness is only for adding a aftermarket amp to your OEM amp to either drive a trunk sub, power the underseat woofers or both as is.
If you want to add more amplifiers to drive the rest of your speakers then the harness itself will have to be cut and modified accordingly. I do not support/warrantee such use but it can be done, however you will need more than just adding another amp (search for JBL MS-8).
