Bimmerfest - BMW Forums - View Single Post - BMW OEM wheels offset problems
Old 07-08-2011, 06:55 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
Originally Posted by DLS_91_525i View Post
I have found a local salvage yard that has a few BMWs that are wreaked and good for parts!
Well I think I'm going to go wheel shopping and was just wondering if any of the 5X120 bolt pattern wheels would have a problem fitting because of the offset?
We'll say 1989 to 1995 models.
Thanks for any help!
E28/32/34 wheels will all work. 16" E38 wheels also but not with the E38 tires fitted.
3 series all have the wrong offset. E39 wheels are correct offset but wrong hub size, an adapter is available, they are called "hub rings" and readily available.
Lots of wheel fitment threads around but above is in a nutshell what you need to know.
Take my advice, I'm not using it.
