Old 07-19-2011, 09:20 AM
JPEG23 JPEG23 is offline
Mein Auto: E63
Originally Posted by Tosh.645ci View Post
How do you know you've gained over 13% more acceleration? Did you measure before and after 0-60 times?
Simple math, 3.91 (new gears) / 3.46 (OEM gears) = about 1.13006 and yes shorter gears lower the top speed. But with the car electronically limited at 155 and a true top speed of around 190; it will still hit max out with ease.
The gear ratio (ex: 3.91, 3.46) means how many times the drive shaft rotates for every turn of the wheels. So for every turn of the wheels my drive shaft turns 3.91 times instead of 3.46; in turn increasing the acceleration of the car, but lowering the speed at which the car switches gears.
Sent from my iPhone using BimmerApp
6 series - Sapphire Black w/ 22" Beyern Mesh wheels
