Old 07-25-2011, 02:50 PM
For the cross-linked record, we discuss the removal of the hoses using only axial forces (Fa) in this thread today:
- E46 (1999 - 2006) > Testimonial: Coolant system overhaul
Other useful innovative solutions were also discussed:
- Tricks to replace the M54 fan clutch nut (1)
- Innovative solution to the M54 lower-hose thermoswitch o-ring (1)
- How to non-destructively remove the brittle plastic radiator nipple (1)
- How to non-destructively remove the brittle expansion tank nipple (1) (2)
- How to properly remove the original OEM BMW Oetiker clamp (1)
- How to not misplace the thermostat wiring loom (1)
- How to properly replace a broken bleeder screw (1)
etc.
All of these were based, at least in part, by mistakes:
- How not to remove the nipple from the E39 radiator (broken radiator nipple)
- How not to put your E39 fan clutch back on (crooked fan clutch nut)
- How not to bleed your E39 cooling system (1) (broken bleeder screw)
- How not to replace your E39 thermostat (thermostat loom misplaced)
- How not to remove your E39 expansion tank (broken expansion tank nipple & cn90 repair)
- etc.
