Old 08-03-2011, 10:03 AM
Originally Posted by - Mover - View Post
I decided to go to a local indy who has diagnostic equipment that could read the ABS fault code instead of continuing to chase the intermittent problem.
And? You paid for it. What did the indy report?
... test the sensors myself. They all showed to be working fine
You should post your numbers in the aforementioned ABS thread.
The fault was being triggered by one of the front sensors.
I'd love to know HOW they hooked up the diagnostic tool to tell you that, for sure.
Changed the sensor and no more warning lights.
I am suspicious that a good DMM wouldn't have told you what you ended up paying an Indy to tell you (and for less money than the cost of the good DMM).
But, the good news is that, if it was the wheel speed sensor, that the problem is resolved.
As many have said, most of the time it's a single wheel speed sensor (which can be diagnosed with a 'good dmm') or the steel wire lifted off its gold bond pad inside the ABS control module.
