Bimmerfest - BMW Forums - View Single Post - Transfer Pump Electrical Connector
Old 08-14-2011, 05:42 AM
Tecmec Tecmec is offline
Mein Auto: 1987 531is
You will need to remove the sending unit (the four bolts on top of the pump unit) before you can remove the pump from the tank. Once the sending unit is removed you can tilt and turn the pump unit to remove it. It will not come out with the sending unit installed.
