Originally Posted by zampag
Ca access to open the door, sat inside, closed door, pressed lock on the fob and the car locked. Normal behavior?
Yes, the car will lock using the fob while inside the car with the doors closed. It will not respond to lock commands from outside the car when the fob is inside, using CA for example, when the fob is in the car or trunk.
BMW-CCA
Bimmerfest Supporting Member
2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
