Old 09-07-2011, 11:34 PM
Originally Posted by dvsgene
BB, will be along soon to put this in the Best Links.
Thanks for the suggestion!
Doing a search for 'rear bearing' in the bestlinks, I find only this:
- Rear axle suspension & wheel bearing installation DIY by mmm635 (bimmerfest, bimmerforums)
So, now there's this:
- Rear axle suspension & wheel bearing installation DIY by mmm635 (1) (2) & rear bearings done the cn90 easy way (1)
In addition, I added a line to the specialized tools section:
How to make your own E39 specialized tools:
- How to make your own BMW cooling system overhaul fan clutch nut counterhold tools (1) (2)
- How to make your own BMW thrust bushing tool (1) or buy them (1) (2) or improvise (1)
- How to make your own BMW car ramps (1)
- How to make your own BMW subframe & differential bushings tool (1)
- How to make your own BMW oxygen sensor removal tool (1)
- How to make your own BMW single-VANOS solonoid socket tool (1)
- How to make your own BMW camber & toe-in alignment tools (1)
- How to make your own BMW hella headlight adjusters (1) (2)
- How to make your own BMW rtab removal tool (1)
- How to make your own BMW upper timing chain locking tool (1)
- How to make your own BMW flywheel locking tool (1)
- How to make your own BMW cylinder head bolt removal tool (1)
- How to make your own BMW cam locking nut tool (1)
- How to make your own BMW crankshaft holder tool (1)
- How to make your own BMW alignment tools (1)
- How to make your own BMW rear wheel bearing tools (1)
BTW, cn90 ... your graphics are getting better & better! What are you using for annotation?
