Bimmerfest - BMW Forums - View Single Post - Case study: Low-voltage dead instrument cluster - no alphanumerics & most gauges inop
Old 09-16-2011, 09:18 AM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
Originally Posted by qsilver7 View Post
also...here's a tip...if you need to check your odometer...you don't need your key or have to turn the ignition on...just press the left button on the instrument cluster and the odometer will illuminate for a few seconds to allow you to record the mileage...then turn off. :d
^^^^^this
And there is also the tip to wait for car goes to sleep (16mins) before charging or disconnecting battery (as a precaution)
