Old 09-20-2011, 12:58 AM
For the record, today yet another E39 owner has had problems getting the viscous fan clutch off ...
- E39 (1997 - 2003) > e39 fan clutch removal, need help
Originally Posted by jcvara View Post
I am trying to finish my cooling system overhaul but cant seem to loosen the fan clutch off of the water pump, any suggestions???
Here are some answers to leverage back to here so others benefit.
Originally Posted by Fudman View Post
There are three common approachs:
1. Use the belt friction to hold the clutch while whacking the 32 mm wrench. (see the Beisan DIY)
2. Use the fan clutch holder tool (~$20) to hold it in place and a 32 mm wrench.
3. Use a screwdriver and wedge it into the clutch to hold it. (This is a cn90 trick)
I find the fan clutch tool works easiest with lowest risk of causing damage. Put a dab of anti-seize on the threads when you reassemble for easier future removal.
EDIT: Fudman provided this ZDMack link in that thread, so others benefit:
ID:	293876   Click image for larger version
