09-20-2011, 08:57 AM
Mein Auto: '04 X3 3.0i
Originally Posted by styllzs
Its a lot of work to get the transfer case out but the actuator sits right on top and is easily removed.
I believe it is, just asking if the crossmember under the transfer case needs to be removed or not to take the actuator out.
For sure the heat shield needs to be removed at least partially to get access to the back of the actuator to remove the electrical plugs.
