Old 09-27-2011, 12:23 PM
puttitat puttitat is offline
Mein Auto: E91 330d
Originally Posted by BMR_LVR View Post
Congrats. I was under the impression that a bad CPS basically caused the car to just not run at all. I learn something new everyday. Thanks for sharing the solution.
BTW, would you be kind enough to check the resistance on the failed CPS? I would be curious to know what the reading was. If it is in the normal range (540 ohms +/- 10%), then that makes the resistance check rather unreliable for establising the health of the CPS.
Just for the fun of it I tried firing up without CPS connected. Ran fine.
The resistance is 728 ohms. Not that my measuring device is the most accurate in the world, but it draws a picture, that the resistance is too high.
