Thread: aux-in
Old 10-02-2011, 01:03 PM
luker669 luker669 is offline
Mein Auto: 2004 645 coupe Black
aux-in
I won't bore you with the install of taking the radio out ,there are plenty of threads on that. If you are like me and think the aux-in in the glove box is in a stupid spot , you should like this. I ran the Wires under the center counsel and came up in the center arm rest .Also at the same time I ran 12V to have aux power ports. Very easy to do ,bought some material at hobby lobby to match 2.50 cents and the spray adhesive was 7 bucks at autozone. The aux-power plugs were 8 bu8cks each.I cut the corner of a old tool plastic tool box to make the piece inside the arm rest.
ID:	295596   Click image for larger version
