Bimmerfest - BMW Forums - View Single Post - 540 mods and SC build
Old 10-03-2011, 10:05 AM
Flug540's Avatar
Flug540 Flug540 is offline
Mein Auto: 1998 BMW 540i 6-spd
Originally Posted by bricas45 View Post
That is an intersting set up dinan has on that bracket and your additions look good. I may just drill out the oil seperator connection and put a tube in sort of like dinan has just to extent hose to back should be really easy. and seal off the CCV of course.
That will work too, you can just cut off that plastic pipe that extends from the stock plate. Another issue that you might have with the stock plate is securing the stock vacuum plumbing to the plate so it doesn't pop under boost
For my setup I made a 180 degree fitting for the oil separator outlet so that I won't have to go around the engine to the oil separator on the front. Instead the hose will come out at the front of the engine and hopefully the 180 fitting will trap some oil as well.
