Bimmerfest - BMW Forums - View Single Post - 540 mods and SC build
Old 10-12-2011, 09:32 AM
Flug540's Avatar
Flug540 Flug540 is offline
Mein Auto: 1998 BMW 540i 6-spd
Originally Posted by bricas45 View Post
will be modding my hose not the plate on mine. This should be easier. I will do this and attach pcv to my intake as a test before full install. I will plug the pipe with something like JB weld. And put a 'T' connector between the oil seperator and the end plate.
This 'might' work. The problem you may run into is space, which is very tight under the manifold. Attached is what I ended up doing. Even the clamps for the U connector wouldn't fit, but the hoses sit VERY tight there so I thought it's OK to leave them out.
I think if I didn't have the plate, I would make one. It's just a piece of aluminum, a few holes and hose connectors, pretty straight forward. The only complication there is the welded PCV pipe, but I ended up not using it after all.
ID:	296854   Click image for larger version
ID:	296855   Click image for larger version
ID:	296856   Click image for larger version
