Bimmerfest - BMW Forums - View Single Post - 540 mods and SC build
Old 10-12-2011, 11:49 AM
franka franka is offline
Mein Auto: E39 540i Sport
Originally Posted by 540alex View Post
This 'might' work. The problem you may run into is space, which is very tight under the manifold. Attached is what I ended up doing. Even the clamps for the U connector wouldn't fit, but the hoses sit VERY tight there so I thought it's OK to leave them out.
I think if I didn't have the plate, I would make one. It's just a piece of aluminum, a few holes and hose connectors, pretty straight forward. The only complication there is the welded PCV pipe, but I ended up not using it after all.
You might want to add a little longer hose so that when the engine rocks on its mounts there will be sufficient slack in the hoses to accommodate the stretch.
I believe the engine rotates clockwise, when generating torque, as seen from the driver's position.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
