Bimmerfest - BMW Forums - View Single Post - 540 mods and SC build
Old 10-14-2011, 07:11 AM
Flug540's Avatar
Flug540 Flug540 is offline
Mein Auto: 1998 BMW 540i 6-spd
Originally Posted by bricas45 View Post
Are you not using the little inlet connection that is on end of pipe? What is the ID of the hose you had to use to go around that oil separator connection point?
No, I completely removed the aluminum pipe connecting the two. The oil separator outlet is 16mm in diameter. The hose I used is 5/8".
