Preparing to remove the panel on a 2000 M Roadster through the radio opening, may loosen/romove the passenger side kick panel. I can see that the fan selector switch is a pull-out electricl connection, see the three cable connected to the lever arms behind the temperature control guage, and see the disconnect on the air selector knob (electrical disconnect, right?). Question is, I cannot see how the cables are connected to the lever arms. By looking at other threads, it appears that the arms each have a round slot the some type of tab at the end of the cable fits int. Appears that I need to move the cable ehough to align the tab on the cable with the opeing on the lever arms, slide the tab through and out. ANyone got a picture of the cable end or advice on how to disconnect and reconnect the cables in a tight space? Thanks!
