Old 10-19-2011, 07:31 PM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
Originally Posted by ioang26 View Post
Ok, here is exactly what I found out is happening.
I took out the electronic board and pressing each button it works but
when I put the board back in the key case you need squeeze it tight and then push the buttons
in order to work. Seems to me that the case button became hard and not flexible enough to
reach make a contact to the board.
I ordered a new uncut key with the shell and I am planning to swap it and see what would happen.
Would the dealer cut / copy a key?
If you can cancel the order. The only place to get a functional key is from BMW.
