Bimmerfest - BMW Forums - View Single Post - BMW Scanner Fault Code List Needed
Old 10-20-2011, 08:54 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Could not find them all, but here is what my older document has matches for:
# Fault codes
ECU Fault type Code/Parameter (hex)
CAS -> IM messages 9304/68, 9906/28 - 0x22419906 9906 Coding,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),at variance
LM -> IM message 930D/64
DME -> DTC 2EF4/E2 - 0x016A2EF4 2EF4 Map thermostat, mechanism
EGS_SMG -> IM message 4F86/38 - no 4F86 but before and after it = 0x02614F85 4F85 Ratio monitoring, clutch E and 0x02614F87 4F87 Ratio monitoring, gearshift 1 - 2
SGMZ -> IM messages 9394/24, 9395/24, 9397/24, 9398/64
SGMS -> IM message 93F3/20 - 0x244193F3 93F3 Key switch,passenger airbag:coding data fault
IHKA -> DTC 9C54/24 - 0x05619C54 9C54 AUC sensor
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
