Old 10-28-2011, 12:07 AM
2002 M54 engine Sucking Jet Pump
Note: The 2002 525i Realoem diagram for the F connector hoses is wrong:
Engine => Vacuum control => Vacuum control - engine
The large hose coming out of the F connector connects to the metal pipe of the sucking jet pump:
Here is a closeup of that sucking jet pump (with the large hose disconnected):
Notice right behind it is a port with a vacuum endcap that can degrade causing vacuum leaks:
Here is a picture of that vacuum port with the endcap removed.
My theory is that this vacuum port 'was' used to connect to the CCV vacuum port when the CCV had a vacuum port that wasn't likewise plugged; but that's just a guess.
ID:	298798   Click image for larger version
ID:	298799   Click image for larger version
