Bimmerfest - BMW Forums - View Single Post - removing resonator only??
Old 11-01-2011, 06:48 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Using a larger diameter pipe will be fine, just make sure you use a proper coupler where the 2.25" meets the 2.5" pipe.
A larger pipe tends to give you increased flow with slightly better HP at high RPM but sometimes a little less mid-range torque due to the loss of back pressure.
I think the Magnaflow full cat-back system uses 2.5" pipe.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
