Old 11-04-2011, 10:27 AM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
Originally Posted by tjspeed25 View Post
I know this is a x3 form but I am having the same 4x4,dsc,brake light. errors on my e90 328xi that follows with a clicking noise after you shutdown the engine... almost sounds like someone pulling a e-brake... So i am guessing the ACTUATOR has gone bad. I will be pulling it this weekend to take a look just wondering if it will be the same setup or is it more like an e60?? Will any transfer case fluid, be lost when pulled?? if so whats the fluid type or a compatible fluid (d4atf redline)... might as well drain and refill...
Not sure if it will be the same as the X3 or not. From what others posted, no transfer case fluid involved.
BTW, if you do change fluid, you have to buy it from BMW. Expensive - around $50 per liter.
Madurodave
My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi
Retired: 1998 BMW Z3
Member of BMWCCA!
