Thread: Coolant leak
Old 11-06-2011, 07:07 AM
Superhart1977's Avatar
Superhart1977 Superhart1977 is offline
Send a message via AIM to Superhart1977
Mein Auto: 2011 328 XDrive
Hope you are all out there, it's Sunday and dealership is closed. So it was an easy fix, you can replace the lower hose from top and without jacking car up and getting underneath. Found the leak!!!! It wasn't the hose!!! But I am glad I am replacing it anyway. The leak is coming from the temp sensor. I guess the green o ring has shrunk and failed. I put back together and filled with water and ran to flush the green antifreeze that must have been done from previous owner. I noticed the dripping coming from temp sensor, I wiggled it and I am certain. The problem is, it is Sunday, BMW closed, can I get an oring from local auto store that will fit and thick enough to seal?
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
