11-15-2011, 07:53 PM
Mein Auto: 08 750Li, 11 MDX, 04 MDX
Originally Posted by EddieAdams
Thanks... but as I mentioned earlier, the weep hole is at the front of the engine; and if it was indeed the weep hole, I would've seen the coolant coming out of there. Also, the leak would be greater when the nose of the car is pointing downward. In my case, when the nose is pointing downward, there's no leak. It only leaks when the nose is pointing upward.
While that is very logical and hopeful, the system is pressurized and may leak any way it wants to unrelated to gravity or position. The olnly way to know for sure is to look. Assuming hoses are clear, Methinks you should do a search here to find the procedure to check the weep hole. I think it is visible to the naked eye.
2008 750 Li Alpine White/Creme
The economy will get worse before it gets worse.
