Bimmerfest - BMW Forums - View Single Post - I NEED an ABS module! I didn't notice it was missing until..
Old 11-21-2011, 12:22 PM
sf2000x5 sf2000x5 is offline
Mein Auto: E53
I NEED an ABS module! I didn't notice it was missing until I removed the headlight! The speedometer doesn't work, there are no ABS or traction lights present, and the fuel gauge is not accurate.
Can I get some help in figuring out the part numbers? I also need the6 torx screws that mounts the module.
Now, I'm not sure if I should find a used unit and risk having the need to have it calibrated. Right now, I'm considering on finding a used unit for around $100 and having it repaired for around $150.
At least I was left with the DSC unit..
