Old 11-23-2011, 06:14 PM
CABimmerNation's Avatar
CABimmerNation CABimmerNation is offline
CABimmerNation
Mein Auto: 2010 750i M Sport
Originally Posted by wjhughes420384 View Post
how does the dinan stage 2 SW drive? did you have a chance to try the stage 1 software?, if so, how do they compare
The stage 1 makes the car very quick 4.3 0-60, from 5.0 stock. Now that stage 2 is installed it shows that it was kinda sluggish out of the hole with stage 1. I believe stage 2 takes it to 503hp/ 580lb ft. I have not tested 0-60 yet but it breaks loose in first and second gear now and pulls much harder. Well worth the $500 extra.
Dinan S3, PedalBox, 22" Agetro rims, H&R spt springs, RDsport front lip, coded, paddle shift retrofit, AlpineMSS HID 8000k. All exterior chrome, roof, roof spoiler and everything behind wheels painted black, wing, side and rear reflectors and door handle trim painted white, light smoke on tail lights. Audio: focal separates, earthquake low profile subs under front seats (crossed over as mid base to support the pathetic 4" fronts), arc audio amps, audiocontrol lcq-1 and epicenter, (2) L7 subs.
