Old 11-24-2011, 05:01 AM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Originally Posted by BrianSnail View Post
Hi Technic,
I'm planning on upgrading the audio system of my E93 M3 with hi-fi system (amp in the boot) with the latest iDrive..I'm planning on having the following installed in the front...
Morel Hybrid ovations & Morel tweeters
Earthquake SWS-8 subs
all connected to an Audison lrx 6.9 amp
With an Audison BitOne processor
I intend to keep the rears connected to the standard amp.
I don't want the installer cutting and splicing around the oem connectors so thought your harness/connectors maybe suitable...what would you recommend?!
Also would you recommend spacers for the Earthquake subs?
All the best,
David
Hi David
I did an E93 M3 sound system using Morel HO in the front and SWS-8 underseat last year: http://www.m3post.com/forums/showthread.php?t=405224
The Morel HO requires an special spacer/bracket to fit your front doors or the magnet will hit the window mechanism. Look at the last page of that thread and you will see the plastic spacer that I created just for the Morel HO and the E92/93 front doors.
You could also take a look at the new Hybrid Audio Carbon speakers for the front: http://www.m3post.com/forums/showthread.php?t=605465 ... no special spacers required, great sound.
The SWS-8 also require spacers.
The HiFi harness that I sell replaces completely the OEM amp so it is not possible to keep it to power the rear speakers.
