Bimmerfest - BMW Forums - View Single Post - Snap-in adapter alternatives
Old 11-28-2011, 10:31 PM
TogMog TogMog is offline
Mein Auto: Morgan+8, (EvaGT), X3 F25
Originally Posted by Luna-01 View Post
Hi,
There is not a physical connection between the phone and the antenna--there is an inductive connection. The cradle contains an inductive pickup that couples your smart phone to the car's sharkfin. This is a direct route to the antenna designated "telephone 1 & 2 and does not relate to BMW assist cellular functions. The cradle holds the phone in a very specific position to align the smartphone antenna with the inductive pickup.
The advantage with the shark fin is that it is outside the car...a cell phone inside a metal car is severely compromised--that's why there are cell towers seemingly every two feet.
A lot of the confusion comes from no two cell phones being the same in layout or
functionality.
All this info is available on the BMW Tech Info web site, which requires a daily subscription for unlimited downloads. You can also find some info on the BMW coders site--look for the combox document. You can see this antenna setup in the diagrams.
so, yes there's a connection, but it is not physical
best
Luna-01
I am old enough to remember when one had to purchase an incar phone kit which had a two part aerial, one part was glued to the inside surface of the rear window and connected to the phone. The other part was glued to the outer surface of the glass and supported the aerial 'mast'. There was no physical contact between the two parts of the window mounted aerial.
In short, as stated above there is no need for an actual physical 'jack like' connection between phone and 'mast' cable.
